Opel Rekord C Coupe 1971
opelmexico
Postleitzahl: 68540
Re: Opel Rekord C Coupe 1971
Ungelesener Beitrag von opelmexico »
a lot of work to do,
best regards from Mexico
dido1903
Postleitzahl: 1000
opelmexico hat geschrieben:a lot of work to do,
Thanks so much!
How are you doing in Mexico?
:beerchug
franky hat geschrieben:wow, i'm with you :o
good luck, you are the mack!! 8-)
gintonic hat geschrieben:Respect !!!
AltOpelAndi hat geschrieben:Dead ! Würde ich sagen :(
Thank you, everybody!
Indeed the situation with the bodywork is very complicated.
But I keep on going!
Opel Rekord D Coupe 1975
Let there be Rock !
dido1903
Postleitzahl: 1000
Some accessories :)
Let there be Rock !
dido1903
Postleitzahl: 1000
The most problem part of the car.
A long time ago the rear right fender has been damaged,maybe because of car accident.
It's been repaired,but very unproffesionally. In result - too much rust from inside.
And Google translate if needed:
Das Problem Teil des Autos.
Vor langer Zeit der hinteren rechten Kotflügel beschädigt wurde, vielleicht wegen Autounfall.
Es ist repariert worden, aber sehr unproffesionally. Im Ergebnis - zu viel von innen rosten.
Let there be Rock !
andysteinmetz
Postleitzahl: 30823
Ungelesener Beitrag von andysteinmetz »
Let there be Rock...trifft es ganz genau :rock Respekt !
That white door will be your motivation ! ;)))
Go for rust in sections that keep the Suspension in direction.
How about the arch behind the rear wheels ?
get the car running - and Friends to work with you that project.
respect again from germany
dido1903
Postleitzahl: 1000
Danke guys!
Etwas neues.
Lenkrad aus Opel Commodore A.
Let there be Rock !
Commkord
Postleitzahl: 95197
Hello,
its a little late but I hope it will help you because your questions because the metal plate from the first page of this block.
http://www.graf-vlad.de/inhalt/alte_kis ... lt-01.html
Nobody knows every number but here you can find the most.
dido1903
Postleitzahl: 1000
Some progress.
One of the most problem spots - the rear right fender is almost ready.
Einige Fortschritte.
Einer der Problemstellen - der hintere rechte Kotflügel ist fast fertig.
Zuletzt geändert von dido1903 am Dienstag 5. Juni 2012, 13:10, insgesamt 2-mal geändert.
Let there be Rock !
dido1903
Postleitzahl: 1000
Und die linke Tür.
And the left door.
I'm using Google to translate from English to German. I hope you understand the translation.
Ich benutze Google um aus dem Englischen ins Deutsche zu übersetzen.Ich hoffe, Sie verstehen die Übersetzung.
Let there be Rock !
