Got em in without shortcut - probably a bit high..A couple of questions please help!
Re: A couple of questions please help!
Does anyone have set KAW springs 65-80 mm on a rekord c?
These are the only short springs i have found and they are very expensive for me
, i found yesterday 2 front manta b short springs ( -40mm so -60mm withe the weight of the rekord) could i use cutted rear rekord c springs for the rear axle
I am a bit afraid of heating my rear springs to make square ends ( to well fit with the car)
Do you have pictures of shortened rear springs on rekord c?
For the short dampers, cause i want to lower the car more than 40mm, i know there are SPAX adjustable gaz shockers but they are very expensive, is there another choice?
If anybody has a good set up ( springs and dampers) to lower the car ( between 60 and 80 mm) , i would be happy
An important point: i keep original wheels 165r14
Thanks to all
Thanks to all
