Streben
omario
Postleitzahl: 94550
Streben
Beitrag von omario »
ch habe ein 1967 Coupé 2 Türen. Willst du meine Streben ersetzen. Gibt es eine Empfehlung für eine Marke / einen Typ, die / der passt? Auch eine Website für den internationalen Verkauf, da ich in den USA lebe. Opel-Classic-car.com hat nicht
I have a 1967 coupe 2 doors. Want to replace my struts. Any receomendation on a brand/type that will fit? Also, a website for selling international since i live in the USA.
Commobub
Postleitzahl: 66740
Re: Streben
Beitrag von Commobub »
Take a picture of the -Streben-.I don't know what you mean, or what you need.
omario
Postleitzahl: 94550
Re: Streben
Commobub hat geschrieben:
Mittwoch 29. Juli 2020, 17:22
front and rear shock absorber suspension. see attached
Greaser
Postleitzahl: 53567
Re: Streben
Beitrag von Greaser »
First gen Camaro parts (67-69) should solve your problem.
I used a set of Gabriel Gas Ryders listed for first gen Camaros, Chevelles, Elkys and diverse other GM models of that era in the front suspension of one of my Commodores. It was plug and play, like they just forgot to put Rekords and Commodores on the aplication list.
Happy hunting ;)
Michael
Greaser
Postleitzahl: 53567
Re: Streben
https://www.ebay.com/itm/174355640529
These shocks should fit. Will not be as wobble-ish as it is now...
The rear ones will need the lower bushing changed to the one of your old struts.
omario
Postleitzahl: 94550
Re: Streben
Greaser hat geschrieben:
Donnerstag 30. Juli 2020, 15:33
Thank you so much. just want to clarify. For the rear ones, i need to swap the bushing from the old struts to the new one?
Greaser
Postleitzahl: 53567
Re: Streben
You're welcome!
Exactly. You will need the lower bushings of your old rear shocks.
omario
Postleitzahl: 94550
Re: Streben
Sonntag 2. August 2020, 13:29
You're welcome!
Please check below and let me know what you think. They are cheaper.
https://www.ebay.com/itm/KYB-Rear-Shock ... 2889367648
https://www.ebay.com/itm/KYB-Anteriore- ... 2877992872
Greaser
Postleitzahl: 53567
Re: Streben
Well, the ones I linked are sportier gas-filled shocks, the ones you linked are more comfortable oil pressure shock absorbers. They will work as well, if you're more on the comfortable side.
omario
Postleitzahl: 94550
Re: Streben
Dienstag 4. August 2020, 06:53
thanks for all your help.
