Opel Rekord C Coupe 1971
Re: Opel Rekord C Coupe 1971
dido1903 hat geschrieben:The wheels are ready - blasted and painted.
Bild Bild Bild Bild Bild Bild
These Wheels are not for the Rekord C :nono
dido1903
Postleitzahl: 1000
Do you think so? :roll:
Opel Rekord D Coupe 1975
Let there be Rock !
dido1903 hat geschrieben:Do you think so? :roll:
Yes! Is for a Rekord D 1973
https://encrypted-tbn0.gstatic.com/imag ... NuvB8324Wg
This is Rekord C Wheel
Motorbremse
Postleitzahl: 45768
Ungelesener Beitrag von Motorbremse »
Early Rekord D 5x14 ET 37 , Rekord C 5x14 ET 27 ...
It works with 5mm distance discs.
Gruß Uli
dido1903
Postleitzahl: 1000
Clar! Danke!
Let there be Rock !
dido1903
Postleitzahl: 1000
The hubs. Also some accessories painted.
Bild Bild Bild
Let there be Rock !
dido1903
Postleitzahl: 1000
gintonic hat geschrieben:found four handels? (doorgripps with locks) in fair condition...can send you two if you email
your adress.
cheers
The handles are here In very good condition! DANKE, Alex!
I have some questions about oil change.
- Where are the points for oil changing for the gearbox and the rear axle?
- Could you recommend me oils for the gearbox and the rear axle?
Thanks!
Let there be Rock !
on one side of the transmission is a four sides plug and also
on the bottom for drain the old stuff.
and rear end you need to take off the cap on the differential
to wipe out the old oil.
viscosity trans 85/90
viscosity rear end 85
can verify tomorrow.
cheers
dido1903
Postleitzahl: 1000
Thanks, Alex! I'll appreciate, if you can verify it.
Let there be Rock !
dido1903
Postleitzahl: 1000
I met a guy who is selling very good interior for Rek C, but SEDAN.
Does anyone know what are the differences between Sedan and Coupe?
I'm asking only for the seats.
Let there be Rock !
